Party 1.3 Model 99
11 years 10 months before #42793 by manual-mecanica
Party 1.3 Model 99 Published by Manual-Mecanica
Good I need help I have a gasoline party that it does not turn on the electro -ventilator when it lifts temperature,
everything works correctly the only thing that the PCM does not send the mass signal to start the electro.
The rare uinic is that medium the VREF that reaches the temperature sensor is 6volt, can it have a raised mass or that value is normal? Ah I forgot has a connected vigia system that cuts the engine when it heats, ah media with the diagnostic machine and the temperature is seen or the PCM is receiving the Ect signal well ???
11 years 10 months before #42796 by manual-mecanica
Manual-Mecanica Response on the subject Fiesta 1.3 Model 99
Hello, I understand that people like to have things well, but you are ability to a car that is already 14 years old. My advice if the switchboard does not send a sign, what do I think are what you are commenting on?
Dot a thermos contact and the direct fan to +, hot water fan operating.
My way of seeing the things that I do not know if it will be correct: I work the workshop to people at 35 euros + materials + VAT. If I looked to check cables and others take 3 hours.
35 x 3 = 105 + 21%<-State taxes. Total 125 euros more or less about 200 dollars. <- That client does not come back or kills me to sticks and does not pay me.
I did not want to be rude, just like you crazy to work and in the end you do not opt ​​for reward.
11 years 10 months before #42798 by manual-mecanica
hahaha you are right because I'm starting and I wanted to leave it well.
I had already thought about that solution
thanks
11 years 10 months before #42799 by manual-mecanica
Now this car has air conditioning, how is the thermocontact connected to the electro wiring?
11 years 10 months before #42805 by manual-mecanica
:( Is it the same fan for A/A and refrigerant system?
The istalacion of the thermos contact can be made independent. of fan to + battery. From fan to thermocontact and thermos contact to -.
When you close the thermos, it sends you negative.
But if it is the same fan for the 2 things, it is your turn to put on and put a diode so that it does not pass you current from one circuit to another
