Mechanics and Automobile Electricity Course
16 years 8 months before #5051 by manual-mecanica
Mechanics and Automobile Electricity Course published by Manual-Mecanica
Content: This course aims to define the elements that form an explosion engine and its operation, as well as learn to calculate the parameters that define the characteristics of the engines.
- Placement of the motor in the car and types of engines.
- Differences in engines according to the distribution used
displacement, understanding ratio, square motor, supercuadrado and elongated.
- Operation of the engines (4 times: gasoline, diesel), (2 times).
- Elements that form the engine, greased system, cooling system, carburetors, distribution, injection etc.
- Motor course in Canbus.
- Theory about engines: characteristics and cycles of internal combustion engines.
- Motor parameters (power, performance, torque, etc.)
- Theory on carburetors.
Automobile electricity course
Content: This course aims to explain the basic aspects of car electricity, commenting on the most frequent breakdowns and their possible solutions.
- Symbology: Electrical and electronic components Basic calculations.
- Battery study.
- Study of the alternator and voltage regulator
- Starting engine study.
- Study of the ignition system.
- Last generation ignition (DIS system)
- Checking the electrical systems of the car with the multimeter, you can see it in Canbus.
- Fundamentals of electronics and applied electronics. You can download these PDF in IES La Torreta
- Instructions for the management of the digital multimeter, you can see it in redtecnicautomotriz.com
Expanded alternators course
- Introduction and types of alternators.
- Elements that form the alternator and operation.
- Voltage regulators.
- Checks and adjustments in the alternator and regulator
- Catalogs of alternators. Wink
- Checking the load circuit with the multimeter
course of diesel injection systems
- Models and description of diesel injection systems.
- EDC diesel electronic regulation
- Cold starting systems
- Rotary injection pumps of the VE type.
- Applications, generalities, structure and drive.
- Low pressure section.
- High pressure section.
- Mechanical regulation of fuel dosing.
- Variation of progress to injection.
- Adaptation devices.
- Stop device.
- Rotary injection pumps \ "mechanics \" and \ "electronic \".
- Common Rail injection system.
- A little history, system description, functions.
- System behavior
- Structure and function of the components: low pressure part, high pressure part: - High pressure pump
- Pressure regulatory valve
- \ "Rail \" or high pressure accumulator
- Injectors
- system control with EDC:
- Sensors
- UCE control unit
- Actuators
- Information exchange
- Integrated diagnosis
- Real example of the application of a Common Rail system to a serial tourism. Injection scheme and electrical scheme.
- Direct injection engines, power supply systems
- Diesel EDC management for a rotary injection pump engine.
- Elements involved in electronic management 1 and 2.
- Adaptation of the injected pump to electronic management.
Supercharged motor course
-INTRODUCTION. Supercharging in gasoline engines. -The Diesel engines. Compressor classification.
-The turbocharger
-The turbocharger of variable geometry.
-Electronic turbo pressure management.
-In volumetric compressors.
-The most frequent questions and responses about Turbos
Links:
part of the message is hidden for unregistered users. Please log in or register to see it.
Part of the message is hidden for unregistered users. Please log in or register to see it.
Leave your opinion greetings
16 years 5 months before #6463 by manual-mecanica
very good corduroy thank you salu2
16 years 4 months before #6975 by manual-mecanica
I am bassing it and I saw the first part parce me great,
it's like a summary of everything thank you very much Brother
16 years 4 months before #6977 by manual-mecanica
I am interested in the automobile electricity course, which of the 4 is the link to lower it?
It would be good to identify them;)
16 years 4 months before #6982 by manual-mecanica
You have to download them to 4 greetings
