shake when you start to fan Alfa 155
15 years 8 months before #10173 by manual-mecanica
shaken when beginning to fan Alfa 155 published by Manual-Mecanica
I have an Alfa 155, that the thrust bearing, the clutch disc And these are in good condition, any suggestion ??? thank you
15 years 8 months before #10174 by manual-mecanica
Manual-Mecanica Response on the Re: shaking when you start fanning Alfa 155
Hello partner, did the engine steering wheel rectified well? Because it is a typical alabeo fault of the steering wheel, it may have hard points and it is not very flat, in that case you have to rectify it with a good stone or change it, tell us to discover, a hug.
15 years 7 months before #10219 by manual-mecanica
UPS, check it and was well spent with the stone, but it was made with rotating stone, I think the ideal is by turner, that is to say that the lathe spends it and left it as the well -smooth and bright brake discs, since when I remove the plate from the steering wheel I am stepped and without brightness, I believed that it is normal that seen that others that others were rectified, give me a light. It is expensive and tedious, since they have an infinity of connectors and always something is badly connected
15 years 7 months before #10221 by manual-mecanica
The problem is the safest in the plane of that steering wheel is the insured failure.
