Distribution points of the Opel Astra 1.6 16V
14 years 11 months before - 14 years 11 months before #14936 by manual-mecanica
Distribution points of the Opel Astra 1.6 16v published by Manual-Mecanica
Hello good afternoon I need the Opel Astra 1.6 16V manual in 2001 and if it were not possible with the brands of the distribution. Thank you
Last edition: 14 years 11 months before by .
14 years 11 months before - 14 years 11 months before #14944 by manual-mecanica
Manual-Mecanica Response on the Re: Distribution points of the Opel Astra 1.6 16V
Disassembly:
Some engines require a modification in the tensioning roller and/or the guide rollers due to possible failures. Refer to the concessionaire.
Remove the air filter box.
Lift and support the vehicle part
Remove the right front wheel
The wheel pass and the upper engine cover does.
Mark with chalk the direction of rotation of the auxiliary drag strap.
Weave the strap removing the tensioning roller. Use a ring key. You can use a 14mm key and grab for the end of the tensioner.
Insert a 4mm pin into the tensioner anchor hole.
Remove the auxiliary drag strap.
Remove the upper cover from the distribution (2).
Support the engine with a cat in the crankcase.
Corsa/Astra/Vectra-C/Signum/Zafira/Meriva Disassemble:
Auxiliary drag belt tensioner and motor side taco.
Install the crankshaft locking pin in the clutch envelope (3).
Disassemble:
Crankshaft pulley screw (4).
The crankshaft pulley (5).
The crankshaft locking pin (6).
The lower distribution cover (3).
The camshaft position sensor (if it carries).
Provisionally mount the crankshaft pulley screw (4).
Turn the crankshaft to the right to PMS of cylinder No. 1 and check the alignment of crankshaft adjustment marks (7).
The adjustment marks of camshafts must align with the upper plane of the butt (8).
Block the piñones of camshafts (9).
Loosen the tensor roller screw (10).
Turn the tensor to the right until the index of the latter stops on the left.
Use an Allen key (11).
Type 1 (12)
Type 2 (17)
Tighten the tensioning roller screw without blocking it (10).
Remove the distribution strap.
Note: If you have to reassemble the used strap, mark with chalk its direction of rotation.
14 years 11 months before #14947 by manual-mecanica
Assembly:
Check that the water pump mark is aligned with the cylinder block mark (13).
the
alignment of the adjustment8)
marks
7 )
and
Tensor8) without
blocking
it
10
16 )​
Direction
of rotation marks on the auxiliary drag strap .
14 years 11 months before #14972 by manual-mecanica
Everything Megabeat says is true but be careful if you are only going to make a change of strap you have your brands and then you put as is, if you do not have to make a tool since this tense belt of the water pump, I do not renege the page but in the Red Ahy a guide to make this tool.
7 years 5 months before #52921 by manual-mecanica
Excuse me, I have problems when riding the distribution band because the band apparently is short. The distribution band, crankshaft pulley The beaders and pulleys of the camshaft are those of the car but I cannot mount the band. What can be the problem?
