Help- Clio 1.6 rn accelerates only
15 years 5 months before #11174 by manual-mecanica
Help- Clio 1.6 RN accelerates only published by Manual-Mecanica
Hello, my name and smarian I am new on these sides, and I would like to tell you the problem I have to see if anyone can tell me what it can be ...
The problem is that the clio accelerates me alone, but not always, in cold it starts perfect, and it is like this for a long time, the problem is when I stop it, and I leave it for a little while, when I want to start again it is accelerated almost up to 3000 At the pace, I clean the butterfly set with clean contacts, I know no more it can be haha ​​.. except that it is for the gas .. that indicates something wrong with the computer, so it does not have a lambda probe emulator, just a relay, when we reset the computer, it is a good time and it describes it ... when we change the lambda probe the same .. it has the new nafta pump ... components that change are bosch: S so I don't know what else to do and I am seriously thinking of putting the tachito up and selling it ... helpaaaaaaaaaaaaaaaaaa !!!!
Thanks and a greeting !!!
15 years 5 months before #11176 by manual-mecanica
Manual-Mecanica response on the Re: Help- clio 1.6 rn accelerates alone
Or take air that I don't think, because it makes it sometimes, or change the step by step again and when you change it leaves contact a couple of minutes before starting it. You'll tell me
15 years 5 months before - 15 years 5 months before #11181 by manual-mecanica
The issue is that the step by step we tried it and is Barbaro: S ... but hey, I'm going to put the old hahaha to see what happens ... Thank you!
Last edition: 15 years 5 months before by .
15 years 2 days before #14418 by manual-mecanica
Hello, my name is Maxi, I have the same problem. The only thing that mine does not reach 3000 do so between 1000 and 1500 rpm, and not only that but it fucks me in handling because it pulls a lot. Now I am making it see. I tell you to change the pump, step by step, the Lambda probe, the temperature sensor and remain the same. The skinny cannot detect what it is, it would be something electric I think. They cleaned him injector, sensors and others, if I am not mistaken, yours is also monophen, because I have the MTV version that is the same Mod 99 engine. I have it to gasoline and never had CNG, so I don't think that is. If you are on the way to fix it, we can go over.
Greetings
15 years 2 days before #14424 by manual-mecanica
If you pull a lot of Checalo disconnecting the TPD and Andalus for how it behaves.
