Cargo circuit problem in Citroen Xsara
15 years 4 months before #11682 by manual-mecanica
Cargo circuit problem in Citroen Xsara published by Manual-Mecanica
HELLO EVERYONE.
I have a Citroen Xsara Year 2000 1.6
From a while to this part the load system has been failing. Initially the battery began to boil, change it. Subsequently send to repair the alternator suspecting that it will load more than.
A constant problem was that in the lights there is a change of power and simultaneously variation in the acceleration of the vehicle.
At some point the battery was completely downloaded and the alternator did not deliver load, so he sent it again.
I installed it and tried again that the alternator does not load. Checking the operation of the load circuit I have realized that there is no tension in the stator. I have not scarled beyond since I do not know the system very well ... I would appreciate any help that guides me to solve this failure.
Greetings to all and that are very good ...
Max
15 years 4 months before #11683 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with load circuit in Citroen Xsara
Hi Max, it is evident that the alternator does not charge either because of the regulator or by the portadiode plate, if you sent it to repair and did not leave it well you should claim who did the job, or try to do it yourself by dismantling it and checking it well, luck and greetings. :)
15 years 4 months before #11735 by manual-mecanica
Thanks Jal ... but I already checked the alternator outside the car and is working properly.
There is a cable that energizes the alternator stator after you contact the vehicle, is it likely that this cable has been cut?
Thanks again ...
15 years 4 months before #11904 by manual-mecanica
The easiest thing to do is put new cables to the alternator are only two cables so I will not deviate to see more problem feeds direct battery and ready, try if you do well do the installation again
15 years 3 months before #12434 by manual-mecanica
Hello, I would priomer what I would do is see if the 12V of excitement reaches the alternator connector when the vehicle is torn, but it would give a parallel cable to see if it loads and confirms that the failure is excited.
If the 12v Miraria get to you if the Cigueñal pulley is turned since it is usually a double pulley attached by a Goam that sometimes turns the extended part on the bottom probating that the apparus of accessories does not turn to the desired laps. I would do it by making a mark that covers the rubber and the two pulleys and start the cars and stop a couple of times, if the brand has moved there you have the failure a pulley of the crap.
