Problem on the clutch pedal.
15 years 2 months before #12768 by manual-mecanica
Problem on the clutch pedal. Posted by manual-mecanica
Hello, I have a Sxara Picasso 1.9 hdi that you have left a noise on the clutch pedal, when changing march it sounds like it was a clack noise!, And without stomping with putting your foot on top I noticed as a tingling in the foot, but then cluties well and changes well that is what I notice, if someone can help me I would appreciate it. Greetings
15 years 2 months before #12775 by manual-mecanica
Manual-Mecanica response on the Re: Problem on the clutch pedal.
Hello greetings ..
you have to make a routine rvision, (visual) to verify that it does not find loose screws, or loose pieces, with the help of a lamp fix at the time of acting the pedal that the necklace slips without problems, many of the noises are probably proven by dirt that results in the pieces, if you fail to see something abnormal, the following is to demolish the transmission and see Clutch (Disco and Collarin press) also the guide where the necklace slides if it has changed deformations.
I hope and find you.
15 years 2 months before #12776 by manual-mecanica
Hello friend, as the fellow Soto73 says, it is most likely that it is the ruleman of push or collar, and to replace it you have to disassemble the transmission, luck and greetings. :)
15 years 2 months before #12783 by manual-mecanica
We were what I thought about the thrust bearing so that we all find out not? That since I am placed I change the clutch kit. Is it normal than with 90,000 km. This happened to me? They also told me a friend who endures it if it does not sound much that in many occasions the car biejo and from there it does not happen, as tomorrow I just fuck and the clutch is destroyed my doubt is what I do! It does not sound much but it feels if you are observative, I endure that you fuck or change it, I would like your opinion to give me.
15 years 2 months before #12789 by manual-mecanica
well .. it's not just the sound problem ..
if it continues .. can cause .. more discomfort. in the long run ..
It is recommended to do maintenance .. to the clutch system. It could be .. that the necklace is starting to spoke. Ho the axis .. this ... disagreeing. It could also be. that the springs of the oppressor dish .. are broken ...
to get out of this type of doubts .. it is recommended that you maintain the clutch system like this .. you will be trashilo ..
