The car progress is rooted when accelerating to the background
15 years 2 months before #13153 by manual-mecanica
Good afternoon friends of the forum, I have a
Stratus RT 97 2.4
the climate does not
work well but there is a minute in Raleti down the revolutions and after a while it goes out but turns well on.
The car progresses normally and changes the normal changes when you accelerate from 0 to 80 km but ..... example when you want to pierce the accelerator pedal the car just revolutionizes but does not progress ....... no longer accelerate and if you step hard on the accelerator Corri and advance well
how much the speed
low He marked the scanner
was made a rectified heads ... because he has a lot of white as steam ...
thanks
15 years 2 months before #13163 by manual-mecanica
Manual-Mecanica response on the Re: the car advance
You may bring problems with transmission better see with a mechanic or with someone more experienced pk of a small problem you can do something more serious luck!:)
15 years 2 months before #13167 by manual-mecanica
I agree, I think of 90% that are the automatic transmission discs.
15 years 2 months before #13227 by manual-mecanica
It is a failure of the box is almost certain to try or tell someone to try it by uploading it in a gutter and slowly taking it out with the two traction wheels on the verma.
15 years 2 months before #13253 by manual-mecanica
You have broken the Chavon clutch to a mechanic that you are going to save a better headache. Isn't it something you can solve with scholarships of tools?
