Problem with Pontiac G3.
15 years 4 days before #14272 by manual-mecanica
Problem with Pontiac G3. Posted by manual-mecanica
Hello, I hope you are all well with health ..
My query is about a Pontiac G3 2007, it presents the next fault, when you light the car in cold it takes a long time to turn on once the car turns on to the first llavazo, now when it runs as a rrepente it feels heavy and if it stops accelerating it, it turns off, for example if in a stop I put it neutral and I do not floor the accelerator is turned off.
If I turn off the car and leave it for about 5 minutes and I turn it on again the fault is removed but after a few quilometers the fault returns. They already scanned it and nothing comes out of starting tests and all good. I don't know what to do .................
I hope you can help me with your comments thank you very much
from Mexico DF greetings to all goodbye ..
15 years 2 days before #14300 by manual-mecanica
Manual-Mecanica response on the Re: Problem with Pontiac G3.
Change the fuel filter
14 years 11 months before #14360 by manual-mecanica
Hello thank you for your answer, try to change the filter but a small detail does not find it for which I deduce that it is inside the gas tank they could tell me how to lower the tank to be able to change the piece in question or if it is a manual that guides me how to do it a thousand thanks for your attention :(
13 years 3 months before #32442 by manual-mecanica
Actually I think your problem goes through the motor refrigerant temperature sensor, makes that symptom, but check and clean the admission and air filter.
13 years 3 months before #32444 by manual-mecanica
Thanks for the answers, the problem was fixed with changing the IAC but if I am interested in the mechanic manual of the G3 I say to learn the car and that the mechanics do not lie to you if someone has it or Aveo version I will appreciate them very much that they have good weekend to all.
