Injection problem
14 years 11 months before #14963 by manual-mecanica
Injection problem published by Manual-Mecanica
Hello, I would appreciate your help very much. I have a torders 93 TD27 engine with automatic box. The issue is that I send it to repair a workshop for fuel loss from the top of the injection pump, seals changed and no longer loses fuel, but the engine has lost power and has increased considerably fuel consumption. When using it in these conditions, the box is covered by demanding up, I have changed the oil and cash filter without major problems, but no longer demanded much.
Also take out injectors to verify them in the test bench and went out with a lot of carbon. Finally, I would like to know if the pump has lost a little and what is the adjustment it has, to verify if it was moved.
What is the caudalimetro?, Has something to do with my problem?
14 years 11 months before #14964 by manual-mecanica
Manual-Mecanica Response on the Re: injection problem
Of course you have,
14 years 11 months before #14966 by manual-mecanica
Yes that has to do !!!
14 years 11 months before #14982 by manual-mecanica
Obio that urges the flow rate since according to the signal that this sends is the amount of fuel that the computer injects you into the engine, like this, now, now my question is your pump is a rattational or linear diesel?
14 years 11 months before #14983 by manual-mecanica
Sorry with respect to the calibracy these are realized in special banks are not done by hand, so you have to disassemble and send it to calibrate just like the injectors.
