I'm looking for Magneti Marelli computer .....
14 years 10 months before #15582 by manual-mecanica
Hello friends, I have discovered the ground pig failure, unfortunately, it is the computer !!!! Plop !!!! So I'm looking for a Magneti Marelli G6.11 OD03 please if someone has a fact that helps me thanks ...
14 years 10 months before #15624 by manual-mecanica
Remember that this computer brings codified key and if you buy one you will have to buy the cylinder and the corresponding key but never leave
14 years 10 months before #15631 by manual-mecanica
It seems to me that the original key does not bring codification now is walking but with an ECU G7.11a but it fails that is why I am looking for the G6 ..... I already did the test and it worked as well with that of another Peugeot 205 of the same year so I do not think I have that problem ... thanks for the datito
14 years 9 months before #15685 by manual-mecanica
Ok No problem I thought you refer to Magneti Marelli incorporated for Fiat, not for Peugeot, well it is actually the same system, if you say that it works you want it works by chip good test and tell us the result once you can do it to have the data.
14 years 9 months before #15704 by manual-mecanica
Well today I have solved my problem. I went to Santiago to look for the computer until I found it, it cost me $ 150,000-Lukas, I return to my city, I will do it and it works perfectly, the datito of a friend who was lava cars on July 10, the old man has everything to everything of the Packet La Cago the Local. The place is called a specialist the page The page is www.eurospecialista.com I hope you serve you the data chao greetings ..............
