I recommend Castrol Oil 20W 50 (made in the USA) since it is the one that meets the lubrication standards and exceeds them by 50%, its detergent property is very strong (clean all the internal dirt of the engine), of spark plugs, you can put as they already told you, the NGK iridium tx, only that they are a bit expensive, for a PT cruiser they were $ 540 (Mexicans) You can look for the NGK G-Power (made in Japan), Platinum fine point, they are cheaper and work very well ... although the spark plugs come, I recommend you recalibrate them, since in the packaging and transport, they could have received some blow and have closed their electrode ... Search on the NGK page the calibration for your car ... greetings ...
