Problems with a CLIO 2
14 years 9 months before #15877 by manual-mecanica
Problems with a CLIO 2 published by Manual-Mecanica
Hello everyone I have a Renault Clio 2 year 2000 Nafta 1.6. in the morning when it is cold does not regulate and stop and already underway when you leave instead do not keep the idle. What can it be?
Thanks Matias
14 years 9 months before #15891 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with a CLIO 2
I have the same problem and it is a 1.4
at first talking to a friend who works in Renault told me to change the crankshaft sensor and the connector and the car was about about 3 days phenomenal but now he does the same thing again, so I still contact my friend, if I have any dire or you can try the crankshaft sensor in case you do well.
all the best
14 years 9 months before #15893 by manual-mecanica
Thanks Karma and I tell you that mine lost oil for the bench retain just when I screwed so I'm going to try
greetings
14 years 8 months before #16809 by manual-mecanica
Hello, I have a Clio II 1.2, and I had a similar problem, the result: olgure in the valves, unfortunately mine is a 16 valves and tube to change them, I hope for your good that yours does not have the same problem. See you later, greetings.
14 years 8 months before #16828 by manual-mecanica
I have solved my problem with the idle actuator, from time to time the mamon was locked in its operation and there would be no air to give way to the interior of the engine and that is why it was dump.
It has been difficult for me to do so because whenever I investigated the car did not fail until the force of making kilometers and giving me the failure to disassemble it in a service area and I saw that the actuator did not move when he tried to tear off the car.
He has been wearing a week and is phenomenal, even the idle has improved a lot.
