Motor problem Daihatsu Ferza 1.6 year 95.
14 years 9 months before #16043 by manual-mecanica
Motor problem Daihatsu Ferza 1.6 Year 95. Published by Manual-Mecanica
The engine works, by accelerating the temperature indicator low to zero, there is also a lot of condemnation of vapors at the exhaust outlet.
14 years 9 months before #16049 by manual-mecanica
Manual-Mecanica Response on the Re: Motor problem Daihatsu Ferza 1.6 Year 95.
Hello, it is not clear to me what kind of vapors that is, it is white smoke or what color. If it is white smoke then it is probably water, water or antifreeze that is going to the combustion camera, you have to look at your antifreeze deposit if you have consumption, that is, if the level low. If water is passing to the combustion camera, you have to take your head from the engine to take it to rectify and change the joint. But I would like you to give us more data to be sure of what is happening.
14 years 9 months before #16055 by manual-mecanica
It is true what Jose says, if it is bapor (white smoke) and it is excessive, that is, a lot Walking, the spark plug cables, that is, I take the first the car you have to get your walk if you do it again and pass the other, and so on until you take out one and the vehicle is the same then that cylinder has the problem and we will see why or let it be unveiled, see that you have a good spark.
14 years 9 months before #16071 by manual-mecanica
Hello friend, look at your delivery few background to try to solve this problem, but I could say that the problems of your engine pass more through the subject of open thermostat or the inexsence of this, now that of the irregular work in low is the product of the same the engine is at a very low temperature, I would like to know if it is with carburetor or injected to be able to continue helping you, this Forum, and well, reading our friends, they are well in their theory but if we are in precede Help you, I hope this serves you something and can solve the problem. B)
14 years 9 months before #16080 by manual-mecanica
Manual-mecanica response on the subject fierce problem solus-
Grace colleague for his cooperation
