Electronic ignition
14 years 8 months before #16538 by manual-mecanica
Electronic ignition published by Manual-Mecanica
Hello, how are you, I have an xsara 1.8i 16 valv ... the problem that I have is about the revolutions, it is not maintained ,, d 900 low, or from 900 rises to 2000 laps ,,,, NEW ,,, NECito Some orientation, some give me on the temperature sensors, or lamda, or I get butterfly sensor ,,, that suggest me ,, a hug
14 years 8 months before #16548 by manual-mecanica
Manual-Mecanica Response on the Re: Electronic Ignition
This fault can be due to the IAC valve, it is often dirty, you have to remove it, C finds in the acceleration body it is electric ...
14 years 8 months before #16557 by manual-mecanica
Thank you ,,,, this, when cleaning it, / iac / that solves me, the relation, or the implementation, hot ,,,
14 years 8 months before #16593 by manual-mecanica
I solve the release and it helps you to the game, but it does not solve it, I think that the best thing you can do is make a scanner because it seems to me that you have two failures together and not only one, it is better to do it so that you are not spending for spending on sensors.
14 years 8 months before #16606 by manual-mecanica
You are right ,,,, I am going to scan, I ask you, when they realize the scanner jumps the current problems ,, or also the oldest ,,,, ask you ,, this ,, because the car bought it 7 months ago ,,, find
