A ZD30 engine injection system
14 years 4 months before #19457 by manual-mecanica
Injection system of a ZD30 engine posted by manual-mecanica
Hello gentlemen ... I would like someone to help me!
I have a Nissan Urban Zd30 SENSILLO Model 2004, and inheritance that until a while ago the
vehicle is caught me as it would run out of fuel
or as it did not reach the injectors because they are electronics
and I have already changed a butt, computer and until recently I also change
the injection pump and the problem persists ... if someone knows something would be
very useful and I would appreciate it very
much
14 years 4 months before #19555 by manual-mecanica
Manual-Mecanica Response on the Re: Injection System of a ZD30 Motor
Normally it starts reviving the fuel supply system as well as its quality, which is not contaminated with water, that there is no air suction, breakage, etc.
Subsequently, the revision is complemented with the reading of fault codes which must be solved. With the problem you can place perhaps in the dosing vàlvula, in the suction pump Ò in the high pressure system where there may be leaks, especially in the injectors.
14 years 4 months before #19556 by manual-mecanica
I had the same problem but with a Corsa recently, the problem was the fuel that loads before the fault began to appear, change gasoline pump and problem solved, I hope my comment helps you.
Greetings
Alejandro
12 years 9 months before #37504 by manual-mecanica
Manual-Mecanica response on the topic injection system of a ZD30 engine
Hello everyone I solved the problem of the ZD30 injection pump because our country we have problems with these electronic pumps and we changed the electronic pump and put a mechanical pump and with this pump the problem is removed to the ZD30 engine will soon upload the images and a video of the engine with a mechanical pump of these mechanical pumps we have installed quite a lot any information just tell me to help you
12 years 9 months before #37522 by manual-mecanica
Hi Grasia for your comment but I would like to know what the bomb was put if it is kind
