Peugeot Partner brake problems
14 years 4 weeks before #22367 by manual-mecanica
Peugeot Partner brake problems published by Manual-Mecanica
: UNSURE: Hello, my problem is with the braking of the diesel motor partner, check wheel pumps, central pump, vessel pump and servo, but I do not find the damage. BRANCH BRAKE PEOPLE BUT NOT EFFECTIVE GIVES APPEARING VACUES IN THE SERVO IN THE SERVO BUT THE ALL SYSTEM IS REVISED IS NOT (ABS) SUGGROD
14 years 3 weeks before #22376 by manual-mecanica
Manual-Mecanica Answer on the Re: Peugeot Partner brake problems
Sorto no mention the problem that presents
14 years 3 weeks before #22378 by manual-mecanica
The problem is that the brake gets hard or tallud
14 years 3 weeks before #22382 by manual-mecanica
I have the same problem with the 2002 partner, it seems to me that it is a vacuum bomb, because the first braking is good and then it becomes too hard, Caulquierr suggestions is appreciated since I am stopping barely, of course, thank you.
14 years 3 weeks before #22387 by manual-mecanica
The problem you have is the empty bomb I already had an equal experience, it is not necessary
