whistle does not enter the camvios
13 years 11 months before #24025 by manual-mecanica
whistle do not enter the camvios published by Manual-Mecanica
Good morning, I have a problem with the transmission does not want to enter the changes, I put it forward and stretch very well but the camvio does not enter, the more the floor increases with velusity but the engine has. I get two more camvios and if the camvio enters, as if the tps censor did not funeate not the checked, I want to have barias oppesions to start, grasias for his atension
13 years 11 months before #24076 by manual-mecanica
Manual-Mecanica response on the Re: Silbad
You talk about automatic
13 years 11 months before #24103 by manual-mecanica
If it is automatic, today I remove it and I will check it that I see, and repaired engines but not transitions although sometimes and open some to familiar with them and the good assemble, I would like Saver, since it would remove it as it would be the best way to repair it, what you devote to bewilder
13 years 11 months before #24115 by manual-mecanica
Huy friend The theme of gearboxes is a bit complicated, it is not very easy to perform and you have to have many precautions, first knowing that the masterkit is very expensive, second the clutch discs bring an order, they all look the same but vary in their thick in microns, the valve body has some balls if one falls and you do not have the manual you will never know where it goes, as a advice I would tell you that I will tell you that I will tell you fix. It is the best the most economical.
13 years 11 months before #24144 by manual-mecanica
You are right, but I open it and the records I take them out in order and Buelvo Aponer all Asia after, I really do not give me anything difficult, and of the packaging kit here they do not come out expensive buying the turbine would be as 280 dollar, because in a normal workshop they would charge with 1,200 dollar, also the balines or balls already look that the figure has the location, since it ends you.
