Ford Ka thermostat
13 years 11 months before #24195 by manual-mecanica
Ford Ka thermostat published by Manual-Mecanica
I would like to know how I can get the thermostat out of the car without breaking it.
13 years 10 months before #24242 by manual-mecanica
Manual-Mecanica Response on the Re: Ford Ka thermostate
If I am not mistaken the Ford Ka thermostat body is on the right side of the cylinder cover, to disassemble the thermostat, you must remove the entire body, it has eight head screws. Any questions consult me
13 years 10 months before #24243 by manual-mecanica
The problem I have is that after removing the body lid, the thermostat stays inside the body and I can't get it out. In addition, although I am sure that the car is heated because the thermostat is wrong, I would like to take it out to check if it is fine without breaking it. Anyway thank you very much
13 years 10 months before #24246 by manual-mecanica
Very rare that this nailed and you cannot take it out, because otherwise I remember to get the thermostat you have to remove two fhilip type screws that would be the lid, and from that lid comes an elbow where a hose is connected
13 years 10 months before #24253 by manual-mecanica
It depends on the engine that has the new focus engine and Mazda 3 that are also from Ford are bringing thermostats that cannot be removed, the housing is plastic and is bought complete and for the benefit of the manufacturer it is more expensive.
