U480 ESCANner OBD II
13 years 8 months before #27300 by manual-mecanica
U480 ESCANner OBD II Published by Manual-Mecanica
Good afternoon everyone buys a U480 scanner to use it in the Ford Focus 2001 that I have but when connecting it everything of the protocols comes out and when you reach the DTC in the main menu and I started to navigate I get the following fault: 01
pend: 00
N/A
01/01
Read the system very well in the vin number and the observation is that I have the light of the check Engine Of the temperature and I do not know if for this reason you cannot read the codes. Thank you and I appreciate the help you can give me.
Nelson Acosta Moreira
13 years 8 months before #27324 by manual-mecanica
Manual-Mecanica Response on the subject Re: U480 scanner obd II
It seems that the problem is that it does not recognize the auto protocol, because with the check it on with greater reason to close the reading, they are in the transition of years and that is why they do not read,
13 years 7 months before #27361 by manual-mecanica
Thank you but you refer to the transition from years.
Nelson
13 years 7 months before #27373 by manual-mecanica
On occasions and depending on the PAIZ when you buy a car in September 2000, for example, that vehicle is 2001 and can bring a different injection system to the 2000 model brings
13 years 7 months before #27427 by manual-mecanica
Thanks for the clarification.
