The car is bought at a Mrs., the main problem was first the oxygen sensor bank one, then the box with the valve body, the valve body was changed and the catalyst was removed to remove the problem, work like this one year without problem and performing maintenance up to date, but now it tells me the mechanic that the engine has to do for the blue smoke that the votes, but the compression is 3 months ago, but the compression 185, the bench sensor is giving problems, the valve lid is Happy Humid, and as if it were little the oil filter came out and I fixed and I miss oil 4 liters I changed the filter and the base of the filter and it is removed but save has a vote of oil for the steope and by the valve body, when accelerating hits but it does not seem box that is why I am looking for the manual
