Corsa Opel Truck Year 97
13 years 1 month before #34565 by manual-mecanica
Corsa Corsa Year 97 Truck Published by Manual-Mecanica
This truck received a blow in the crankcase sector and after a challenge did not want to walk more it feels that the fuel pump does not work and if I give direct current to the pump it works, but still does not want to start the engine, apparently it does not reach the current to the injectors and I am thinking that it is the same rely that reaches the gauges of edible or kiss has a benzine blocker by the blow but where it is located?
If someone wants to suggest something I will be very grateful, thanks
13 years 1 month before #34568 by manual-mecanica
Manual-Mecanica Answer on the Re: Opel Corsa Truck Year 97
hello!! Check the relay is violet that controls the passage of fuel for the year of your truck I am sure it can be failing! That if the pump works live !! You have to get it out of the fuel tank to fill a hurry with fuel and try to see what happens !! greetings
13 years 1 month before #34574 by manual-mecanica
Hello
, apparently, your problem began with the coup in the Carter area, I would recommend you check in the piñon section of the crankshaft we have the position sensor, if it is beaten or moved by the coup we will not have an impulse of ignition and therefore does not turn on the engine.
13 years 1 month before #34627 by manual-mecanica
Check the impact sensor, it is an emergency button that in case of collision or strong blow is deactivated and cuts the current to the fuel pump,
13 years 1 month before #34940 by manual-mecanica
Hello, I really appreciate the information, it was actually the violet rely that is in the companion sector and I had to run a tooth of the distribution strap because when it was walking it gave explosions and I remain a little advanced according to the gun but it turns like before and it must be because the crankshaft position of the crankshaft must have been run a little by very strong the coup thank you very much
