URGENT HUMO BLANCO 206 1.9 2004 DIESEL
13 years 1 month before #34739 by manual-mecanica
URGENT HEMO BLANCO 206 1.9 2004 Diesel published by Manual-Mecanica
HELLO. I have a 206 1.9 D 2004, the problem is that when starting it normally, when the pre -warmters stop working begins to fail with white smoke by the exhaust, I disconnect the solenoid that is under the pump and stop smoking but with a loud noise to pistono ... thanks
13 years 1 month before #34752 by manual-mecanica
Manual-Mecanica Response on the Re: Urgent Smoke White 206 1.9 2004 Diesel
You have water consumption, if it exists it is a cylinder head, if it does not exist, one or more injectors can be failing.
13 years 1 month before #34754 by manual-mecanica
The engine if it reaches its normal operating temperature?
13 years 1 month before #34757 by manual-mecanica
Recommendations: First check injectors (adjust nozzles or change), second in case the injection is good, check taque adjustment, you can possibly have poorly regulated valves, this is within the most normal I hope it helps you
13 years 1 month before #34760 by manual-mecanica
Check the following:
Oil leaks
Check them if they drop
Refigurant temperature sensor
Sensor crankshaft
wiring
Motor control module
if your vehicle carries turbo check it
