Girenti whistle
13 years 3 weeks before - 13 years 3 weeks before #35109 by manual-mecanica
Girenti whistle published by Manual-Mecanica
First of all hello everyone and thank you very much !!!
You will see a few weeks ago I had an accident with my vehicle because a dog crosses myself on the highway. Take my Ford party to an official workshop and now that they have given it to me, a weird noise sounds in the right area of ​​the engine looking from inside the car. A beep sounds when I don't accelerate and when I start accelerating it is removed. It's like a squeak ...
I have taken it again to the workshop and gives me the feeling that they want to wash their hands, both they and my insurer.
The workshop tells me to call the expert but do not believe it is covered because it thinks it was not because of the accident, but it did not sound like this before:( .
My car has 60,000 and tells me thus to the naked eye that he thinks that the water pump can be and that this would be about 600 euros because he has to change the distribution strap. Everything sounds like Chinese because I thought that if the water pump is bad, the logical thing would be to heat the car and lose water but nothing happens to my car.
It goes as usual only that a whistle sounds to idle.
I have achieved everything that touched me as a car to fix myself to see if you can tell me if I could be from the accident or that.
Materials:
Set Filter
Radiator Oil Motor Channel
Inf Radiator
SUP RADIATOR
CONJ FLATHER RADIATOR
Airbag
Control Airbag
Board instruments
Airbag
Airbag Board Airbag Inf Boop
Fao Dr
Pilot
Tr
iz Condenser
A/C Registration dl dl embellishing
registration
dl
plug
dl
Front
dl
Iz
baragolpes
TR
SPOILER
PARAGOLPES TR COVER​
​Dr lighter
TR z pilot
Replace UD Control Airbag Replace refrigerant fluid
A
C Replace A
C
condenser
replace
dl grid DL Dl Cap replace DL
replace DL
replace Iz bumper support TR
replace spoiler bumpers tr
align convergence DL wheels
by the way in the workshop tell me that they did not touch anything that was near the engine, which only touched the radiator area, bone from the engine forward.
Thank you very much and I feel the billet: blush:
Latest edition: 13 years 3 weeks before for .
13 years 3 weeks before #35118 by manual-mecanica
Manual-Mecanica Answer on the Re: Girenti whistle
The parser was like the dog Ajjajajja, of everything you named nothing can produce a chillido, now the noise is a bit complicated in the forum since what for you is a chillid common. The other thing that could be is the hydraulic pump, but the water pump puts a stronger noise than a chillido, the hydraulic if it does.
13 years 3 weeks before #35124 by manual-mecanica
Thank you very much for answering. The dog was giant !!! What a scare ... : Woohoo:
The whining that sounds is similar to this
*Although not so sharp and by accelerating it disappears completely
My car is a Ford Fiesta Trend Tdci 1.4.
I do not understand anything of a mechanic but it seems strange that it is the water pump and it also seems strange that the blow has nothing to do with this fault. : Angry:
I don't know too coincidence, don't you think?
13 years 3 weeks before #35134 by manual-mecanica
Hi Sasanita.
I agree with Kikemec that it can be belt voltage, to get out of doubt, when it is playing some water on the strap in the pulleys area, if it is removed, it is the tension. Luck.
Miguel
13 years 3 weeks before #35136 by manual-mecanica
Very good, if it seems a matter of tension, but it also influences this displacement of the elements, I mean, it has been able to "revive" the support of the alternator or steering pump, even some pulley. Anyway, in a blow of those characteristics, they should check the proper functioning before delivering it and if it makes that noise and they have given it to you, it is as if they had not finished the work, we are not logical, give them cane that all the work they have done to you are very high benefits so that they do not curmen it as it is due, Ale, luck and I hope I have helped you help
