PEUGOOT 306XR DISTRIBUTION Belt assembly
13 years 1 week before - 13 years 1 week before #35518 by manual-mecanica
PEUGEOT 306XR DISTRIBUTION Belt assembly Published by Manual-Mecanica
Hello everyone, my query is like placing the distribution strip of a Peugeot 306 xr year 94, which I remove, when installing it x first time I do not have problems but tube a problem in the cylinder head and the tube that re -withdraw, but now at the time of installing it does not start, revise the ´Puntos de synchronization according to manual. Cams but my question is that it does not match when I check on the back in the steering wheel that matches the steering wheel zip window with the pms -pm Now I don't know if the brands are the right one can tell me which and where are the correct synchronization marks and in which peak that the steering wheel zipper with reference to the position sensor and the marks in the front part ahh a obs the mark of piñon jacket of crankshaft marks up when it is synchrined as manual and to the other end of the same pine Help
Latest edition: 13 years 1 week before by .
13 years 1 week before #35527 by manual-mecanica
Manual-Mecanica Response on the Re: Mounting of Distribution Bir
What displacement is the engine ????
13 years 1 week before #35558 by manual-mecanica
It is 1.8cc
13 years 1 week before #35561 by manual-mecanica
Here is ... the bencinero
ATTACHING FILE:
File name: CORREA.ZIP
File size: 272.93 Kb
Luck
13 years 1 week before #35570 by manual-mecanica
Hello, in the figure that you send me, of the brand that is on the pulley of the camshaft to the brand in the pine sensor. Thank you
