Ssangyong Rodius
12 years 10 months before #37104 by manual-mecanica
Ssangyong Rodius posted by Manual-Mecanica
The check engine is turned on and loses power. It is happening to me at 120/130 km/h when I release the accelerator or at the beginning of a slope. I turn off and turn on and disappear again. Do you know what can be? It is recourse changed all filters.
12 years 9 months before #37217 by manual-mecanica
Manual-Mecanica Response on the SSANGYong Rodius
I think the first thing you should make a diagnosis of engine failures, and see what faults the engine switchboard has registered, by the symptoms it could be the potentiometer of the accelerator pedal, greetings and I hope it will help you
12 years 4 weeks before #41889 by manual-mecanica
Don't you know what unofficial device a reading of the Rodius switchboard, or Rexton 2005 can be made?
Thank you
12 years 3 weeks before #41907 by manual-mecanica
Almost all the OBD2 scanner can do that task, but it is true what Lord says you have a scanner first before changing things to change. They can be many things to try
12 years 3 weeks before #41914 by manual-mecanica
Thank you, this car is a bit "delicate" in this regard, at least the 2005 Rexton 270xDI, carries Delphi and there is no "economic" diagnostic device that connects. I have tried the ELM327, Creadervi of Launch and the Solus. None has worked, Rex 1 is not obdii.
Greetings
