Please help
12 years 8 months before #37930 by manual-mecanica
Help why published by Manual-Mecanica
Hello, how many people do I need to help me discard it. It turns out that I have an automatic megane 2002 I made the box she makes the changes well but when brake hit as if they had crashed from behind what that can be that the box has everything new inside that it makes it both in cold and hot
12 years 8 months before #37931 by manual-mecanica
Manual-Mecanica Answer on the subject helps please
Good evening
your problem is resonous by monitoring the Lok Ap of the converter or block of the torque cnverter, verify whether to step on the brake not of unconcerning, or the solenoid is evil, which does so. It is fortunate partner.
12 years 8 months before #37932 by manual-mecanica
Thanks Supermaquina but I don't understand you friend how I try that vareja: UNSURE: mela more slowly
12 years 8 months before #37971 by manual-mecanica
The problem that your transmission presents is electronic, you have to replace the online control and lock up electrovalves, in addition it is most likely that it is also the oil pressure sensor. Annex information to repair your problem.
Kind regards
12 years 8 months before #37973 by manual-mecanica
Thanks Pekamillenio tomorrow I will review that
