Help, my civic ex 2006, does not turn on.
12 years 7 months before #38494 by manual-mecanica
Help, my civic ex 2006, does not turn on. Posted by manual-mecanica
Hello, everyone. : Dance:
Please help.
Buy a 2006 Civic, 4 doors automatic and does not start.
This car is recovery and I already did a thousand things and does not turn on.
They turn on all lights but the board does not go.
I already check the fuse modules under the steering wheel and the one inside the engine, together with the battery and apparently everything is fine.
If anyone knows an expert in Honda and I can start it please contact me, (I hope I do not charge very expensive)
I am in Mexico DF very close to the airport
I am desperate I have been a month and nothing.
12 years 7 months before #38496 by manual-mecanica
Manual-Mecanica response on the subject Help, my civic ex 2006, does not turn on.
Cheka the computer or looks under the board in case a current switch has hidden to avoid the robbery of the car I have used it in all the vehicles that I have had and has served me in 2 cases of possible theft.
Greetings
Enrique
12 years 7 months before #38507 by manual-mecanica
Having first the first, does not start because it lacks spark or due to lack of fuel, depending on this is what you will have to check.
12 years 7 months before #38513 by manual-mecanica
He has no spark, does not go, does not make any noise any response when turning the key, if he has gasoline, already check if there is a corturient and does not have. Yoooo. You have a pair of cables cut under the board, I don't know what they are, maybe that is the problem, but how to know if any module or something is missing?
Thank you very much for your answers.
12 years 7 months before #38529 by manual-mecanica
haaaaaaaa you confuse me when the key is not activated even the starter engine anything at all? or turn but the engine but starts?, it empigns checying the captor of the crankshaft or disk if it is with a distributor to eat.
