You eat the pneumatic ones ..
12 years 6 months before #39103 by manual-mecanica
Pneumatic ones are eaten .. Published by Manual-Mecanica
Hello, how is that going ... I have a Ford Tourne of a colleague with a problem on the right side, wears the pneumatic on the outside, it has aligned it a couple of times and they have reduced it but it seems that it still wears it a bit, I have put a level on the tire and it is more inclined than the right side, the shock absorber seems that it has nothing? And what I have observed that in the bass it has what it seems like a compensation but that is another issue, the question is to solve the wear, I have thought about putting a couple of pimpitas with a cocacola can to interact that the wheel nods by right
12 years 6 months before #39115 by manual-mecanica
Manual-mecanica response on the subject The pneumatic ones are eaten ..
The best way to achieve the end, is to put a thinner bolt in anchoring to the shock absorber to achieve the times of a Chinese eye and be able to regulate inside or Asia outside, if you do not want to put a thinner bolt then you have a Chinese eye in the shock absorber, this is valid for the shock absorbers that are affirmed to the dough through two orizontal bolts.
12 years 6 months before #39140 by manual-mecanica
Kikemec, how is that of the Chinese eye? What function has and how it works, this tourner eats the right pneumatic on the outside, I would run the shock absorber inwards? thank you
12 years 6 months before #39141 by manual-mecanica
As you say that regulas making a larger hole or a smaller bolt and tightening in the position you want, I have seen regulation with washers made with coca plate
12 years 6 months before #39144 by manual-mecanica
This is what you say, the Chinese eye is the same bolt hole to do it oval is once round so you can play in and out to achieve the fall. Why do we talk about the front wheel, right?
