Petroleum engine is heated walking and in neutral no
12 years 1 month before #41505 by manual-mecanica
Hello, I hope someone can help me, it is a 3/4 truck Hyundai without turbo that in neutral in Relenti and keeping it accelerated it does not heat up but if it is about 20 kilometers it heats up and has me intrigued what can it be?
12 years 1 month before #41532 by manual-mecanica
Manual-Mecanica response on the oil oil theme is heated and neutral
mmmm you could have problems with the bisco or the covered radiator, or problems with the cylinder head, when you inhabit the water tank sounds pssssssssssss or not?
12 years 1 month before #41583 by manual-mecanica
Thank you partner but we are not going to open it because it must be a button as you say because there is no other possibility because the radiator gets pregnant and all the maintenance of filters and oil is done and it remains the same. thank you
12 years 1 month before #41585 by manual-mecanica
Hello, a more common failure of what is believed is the lack of flow driven by the water pump, tries to check the states of the impeller of the pump to avoid cavitations, adds anticorrosive to 30% to ensure, you tell me ... Salu2
12 years 1 month before #41634 by manual-mecanica
It is true what Nhanriquez says, now that I remember something similar with an SJ413 when putting the engine walking the pump he stopped working and was heated Checala.
