Compression Ossa Phantom 250
12 years 1 week before #42109 by manual-mecanica
Compression Ossa Phantom 250 posted by Manual-Mecanica
Hello very good to all, it is the first time I enter here and I hope you can help me, thank you all in advance.
Well, you will see a 250 cc Ossa Phantom, they told me a technique called "squish" that serves to check the distance between piston and the combustion camera, in a 250 the distance can not lower from 1 mm, mine with ack joint exceeds 2mm, without the joint more than 1mm, my question is, if I remove the brown joint still will have that margin. Motor without the Board, even while being very sure that the piston does not touch in the butt?
I await your answer thanks.
12 years 1 week before #42111 by manual-mecanica
Manual-Mecanica Answer on the subject Compression Ossa Phantom 250
The Board is necessary, the compression would be escaped if you do not put it.
I do not know that engine, but normally what is done is to take the cylinder head to plan and there are removed 1, 2 or 0'1 what you need and if a casual you spend you mounted the joint 2 or 3 that are thicker.
12 years 1 week before #42112 by manual-mecanica
Alex finds out if you get bronze packaging, or you can do it yourself if you get a piece of sheet, the bronze is moldable fits perfectly, I have done it with a 350 chevrolet engine for pikes and seal perfect, remember to paint the joint with acrylic paint to seal better test with that
12 years 1 week before #42133 by manual-mecanica
Bata is right, I have done it for joints of deep civic and mitsubishis and they walk blows but you should put together if you do not lose comprehensive and you will have many problems with oil leaks and it will be a mess.
12 years 1 week before #42196 by manual-mecanica
Thank you very much to everyone, you have helped me, I will choose to plan the cylinder head
