ELECTRICA FAILURE LIGHT SYSTEM
11 years 8 months before #43913 by manual-mecanica
ELECTRICA FAILURE Light system published by Manual-Mecanica
How friends good morning, it turns out that in recent days when a automatic Nissan Sentra 1984, I fell into a pothole to circulate in my vehicle and the lights went out, both those of lateral and rear signage, and those of lighting, that is to say I stayed without lights, I only have a focus on, this does not realize until the next day, mainly because I was not yet very dark, the thing is that I initially thought that I was initially Less those in the interior they work, maybe it was coinciding with the blow to the pothole, but I would like to help me, I do not have the lid of the fuse box so I would help me a lot of one where you can read what function each fuse and relay that is in it, and in the second they help me solve this, perhaps if they guide me with a diagram of the lights would pave me in much the way, anything we are aware of it, anywhere, we are aware of the way,
11 years 8 months before #43916 by manual-mecanica
Manual-Mecanica response on the subject Electric Failure Light System
Hello friend for that is the multimeter you have to check the wiring the voltage that is reaching the lights if not then we go to the relay or fuses it is only a question that you are looking for you do not occupy the manual and more for the year that is the car almost does not bring anything electric
11 years 8 months before #43918 by manual-mecanica
If it was the product of the pothole, then it can be a cut or something is released, checked by hand the electrical system can even be that the telecoming with the blow and it is a matter of putting the plug in its cytio and nothing else.
11 years 8 months before #43922 by manual-mecanica
Thanks to both for answering, in terms of what they tell me about multimeter I can tell you that it does not reach anything to anything, so as to the relay I do not know how to check them to know if they are open or not, and of the telecomando, I do not know exactly where I locate it, so I would appreciate its guidance, greetings ....
11 years 8 months before #43930 by manual-mecanica
The telecoming is the command where the lights that go behind the steering wheel, where you tour and put low and high position lights, want to be unplug and nothing else, check that first to fail relaxes of everything is like deficile.
