Mitsubishi L200 body vibration
11 years 3 months before #45730 by manual-mecanica
Mitsubishi L200 body vibration published by Manual-Mecanica
Hello friends, I tell you, I have a mitsubishi l200 diesel, year 2010; It happens that when it reaches certain revolutions, 1500 to 2000 rpm the body vibrates that scares, begins when I go in 3 and step to 4 as at 60km/h, but for example if I pass from 3 to 4 as at 70 km/h, approx. 2500 rpm. He vibrates anything, putting the 4x4 h tbn vibrates, but in 4x4 l nor flip; I already changed the rear cardan, clutch kit and wheel rectified, TBN I took the front card and tried without this but the same vibrates, changed rear differential bearings, tbn was made alignment and balancing, in fact it has new tires, but the vibration still exists and does not decrease at all, it is worth mention Vibration and transmitted throughout the body, I hope you can help me, thank you very much!
11 years 3 months before #45733 by manual-mecanica
Manual-Mecanica response on the topic vibration in Mitsubishi L200 body
Hello, check the engine-cabin tacos (Flacks) in case there was any broken or loose and let it move "everything" when accelerating it ... greetings !!
11 years 3 months before #45758 by manual-mecanica
Dear friend The L200 has a balanced axis inside which is synchronized with the respective marks for it, if it is not at its point, instead of absorbing engine vibrations it generates even more. I hope the data is useful ... ;)
8 years 3 weeks before #52315 by manual-mecanica
Dear:
Did you solve your problem? It happens to me exactly ... I have spent the clutch kit, I put a fence.
Tell me if you could solve it for FA.
Thank you
7 years 3 months before #53036 by manual-mecanica
Hello, I have exactly the same problem in the third vibrates a little but as soon as I put 4 to 60 km the carroser vibrates me, I already changed the downtown balinera, change the 2 motor supports, change cash supports and the vibration follows the same in 3 and 4 .. that someone helps me because the vibration follows the same thing and I want to save what is what I have to replace if the problem is in the box.
