Toyota Tercel 2E Dead Cylinder
10 years 9 months before - 10 years 9 months before #47293 by manual-mecanica
Toyota Tercel 2E Dead Cylinder Published by Manual-Mecanica
Hello, a greeting atodos in the forum .. I have a Toyota Tercel 2E that the time band was burst .. Based the butt, the damaged valves were changed, the valves stamps were changed and re -assembled again, but now the same cylinder that is found does not work, we verify the spark plugs, the cables and it works and there is current in the spark plug but the cylinder is dead. In three cylinders, when this walking is done and it is that cylinder that there are no changes .. Some help if you know the problem ... SALUDOS
Last edition: 10 years 9 months before by . Reason: Orthographic lack
10 years 9 months before #47300 by manual-mecanica
Manual-Mecanica response on the topic Toyota Tercel 2E dead cylinder
I suppose that they will have verified valve regulation (I understand that it is engine carries 12 of them).
You would have to check the compression of that cylinder to see that it is not low.
10 years 9 months before #47394 by manual-mecanica
Now there are 2 dead cylinders on the 2 and 3 and the worst thing is that the engine is ringing that it was anyl problem but it is not so that it could be
10 years 9 months before #47396 by manual-mecanica
Try to see if the compression of one cylinder to another passes by putting air to pressure through the hole of the spark plug and with the closed valves in which the air dwarfs, with this you will know if the cylinder head is combined and that is why they do not work on 2 and 3. Greetings !!
10 years 9 months before #47413 by manual-mecanica
It is with chauchas, they rectified butt, and the bolt torque is fine, if so, they measure compression if there is then done oil to the cylinder and try again, if it greatly increases there problems with the rings.
