Tiida 2009 clutch
16 years 6 months before #6147 by manual-mecanica
Tiida 2009 clutch published by Manual-Mecanica
Hello, I am from Mexico, I have a Tiida 2009 that presents a problem on the clutch pedal, it seems that it loses pressure, I would like a point of view, so that they do not see my face in the agency's workshop. greetings!
16 years 6 months before #6150 by manual-mecanica
Manual-Mecanica Answer on the Re: Tiida 2009 clutch
Give us a little more details to help you better, do you a little more specific is hard, very soft, skate? We will thank you. :)
16 years 5 months before #6163 by manual-mecanica
I think the same is missing information is hydraulic or mechanical clutch, this long or short, hard or soft, has noise when stepping on or releases. We can there but give us data, greetings
16 years 5 months before #6276 by manual-mecanica
More information is needed, if you feel that he skates or gets hard or you are soft, at the moment I can help you that you do not set foot in the clutch pedal or clutch mystras accelerates, that makes the clutch wear more quickly and improves your handling habit, but if you require that you specify the symptoms that it presents
15 years 11 months before #8616 by manual-mecanica
Friends I am from Venezuela and until last night the clutch worked perfectly, in the morning after heating it a bit when I went to place the 1st march I noticed that it did not work, I clarified, the clutch pedal sinks completely but without pressure (only a little at the end) and you can wear the march but for the start of the vehicle it is only needed to release as 10% of the normal route to start walking. I do not know if it has to do with the fact that it lacked liquid (Dot-3 brake league) in its tank because I think there are both systems are interconnected. The brakes work very well. I was told to request the clutch Kiit but it cannot be because that system in any vehicle is spent at night for the morning and with the vehicle off. I thank you for helping me.
