Mercedes 300e year 1990
16 years 5 months before #6738 by manual-mecanica
Mercedes 300e year 1990 published by Manual-Mecanica
I have a 300e year 90 that he gets down, it has me sick, I don't know what to do, I changed the water pump, I raised the radiator, I want to go on vacation, but I am afraid to melt it on the way to the south. Any friends will thank you.
Trucker40
16 years 5 months before #6760 by manual-mecanica
Manual-Mecanica Response on the Re: Mercedes 300e year 1990
Verify if the fan works either electro, but I think that yours is thermogutyer, answer me if it works and if the water level low or maintained, if there is any leak or something, if all this is fine, take out the thermostat and leave it like that, do not buy a new one only leave it without it, if after all this it heats up the same, take out a spark plug and be if it is also Emulled, just get the oil filling lid and see if there as a cream, either of these last two alternatives are serious, and you should change the cylinder head gasket, now if it is only on low and when you go speed you take the most caused thing is that it is only the fan. Chea and let me know so that you enjoy your vacation soon.
16 years 5 months before #6768 by manual-mecanica
Thanks my friend. The thermostat already took it out, the spark plugs are new, and thank God the water is not passing to the oil, so the packaging is fine. I insist, it has me sick ... but I love him hahaha
16 years 5 months before #6770 by manual-mecanica
As for the water, when the radiator took it to envillar it, we saw that greater revolutions, sent more water, changed the pump for a new one, but the problem is not solved. I saw how water almost did not throw it down, but when the hose accelerated it, the amount was full of the radiator, I must have lost a drum doing this experiment, but from there I went to buy the pump, with the new one I do not throw either ... I insist, it has me crazy
16 years 5 months before #6807 by manual-mecanica
You have not said if the fan is electric or mechanical apart from the themes if you take it off everything in low can lower what the fluflo is since you modify the passage of separate water you have seen if it has any valve of the system that has been open and is deviating the pressure somewhere and what temperature it comes to you.-
