Help .. Problems with the fan ..............
16 years 5 months before #6740 by manual-mecanica
Help .. Problems with the fan .............. published by Manual-Mecanica
Help me please .... I have a Ford Fiesta 2004 ... When I bought it, it took it to enter the fan ... now even while the normal temperature is in but it takes to go out ... I am not going to burn ... the refrigerant liquid is normal ... normal philters ... which could be ...?
Help .. Thank you
16 years 5 months before #6761 by manual-mecanica
Manual-Mecanica response on the Re: Help ... Problems with the fan ..............
Check the state of the temperature bulb, if the fan run is fine, also try to remove the thermostat, you want this medium stuck or it takes to open.
16 years 5 months before #6764 by manual-mecanica
Hello,
look if the fan throws well or goes half braking if it has air conditioning that does not have much dirt between the 2 radiators and also the councils that already gave you
luck
16 years 5 months before #6790 by manual-mecanica
Sorry, change the offer, check the Bulvo of the electro fan, is down the radiator, if it is the original change it, it is spent, and that they control the electro's relay this usually fucks too, but if the auto heats in normal time the thermostat has nothing, and that this dirty among the radiators I do not think it is the fault, please, after you give us on the key to the key!
Salu2 and luck
16 years 5 months before #6803 by manual-mecanica
Check if the bulb is two starter temperatures, the first one has been damaged, it would be to drive the fan first still low speed and then to another much faster you can try it by making a bridge in the connector that leaves the electrovalve.
