Renault gearbox problem
16 years 3 weeks before #8301 by manual-mecanica
Problem with Renault Changing Box Published by Manual-Mecanica
The car suffered a overturning and was repaired. In the gearbox does not enter 1 and 2nd, the others work well. I appreciate your help
16 years 3 weeks before #8327 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with Renault Changing Box
SUGIUYE The gearbox is the best you will do
16 years 2 weeks before #8349 by manual-mecanica
Hi, I'm Horacio, maybe the problem is the box itself and not because of the overturn you would have to have and relieved in granages
16 years 2 weeks before #8410 by manual-mecanica
I think the same thing that Horacio is impossible to have if you do not take the box, but I can tell you that the second will not be very good in the vehicles is direct if you do not enter you can find the axis or destroyed any of the bearings, well you have to take it out anyway.
16 years 1 week before #8471 by manual-mecanica
Thanks friend for your answer. I will take your suggestion into consideration
