NISSAN LD20 Motor Help
16 years 2 weeks before #8384 by manual-mecanica
NISSAN LD20 Motor Help Published by Manual-Mecanica
I would thank you for your help with a problem with Diesel Nissan LD20 engine, the theme is as follows: the engine is disassembled and rectified again by a reheated and when assembling it it is purchased that the gears of the camshaft and that of the crankshaft did not have marks which hindered us the assembly in syntis the engine starts well and it is heard well but it does not yet it does not yet it. And I discovered that the air filter is filled with exhaust ollin The consultation is the following someone has the distribution diagram of that engine? Well, I would like to corroborate the tuning I do not go since this engine is with a distribution chain and tree to the head it is supposed to be LD20 year 1987 thank you very much
16 years 1 week before #8390 by manual-mecanica
Manual-Mecanica Answer on the Re: Nissan LD20 Motor Help
Friend:
You could specify whether this engine is in a Nissan Bluebird (U11) or in another model, since it has some modifications according to the Don model is installed, even the synchronization point varies.
Greetings.
16 years 1 week before #8392 by manual-mecanica
Friend: Nissan LD20 engines, from 1987, came with a distribution girdle, not with chain, I have the manuals and I can't find Ca dena. The LD28 if I had a chain.
Greetings.
16 years 1 week before #8398 by manual-mecanica
I would not know what vehicle comes here in Argentina, they entered as a scrapping engines from Japanese here they were sold to put them in other cars, in the entrance papers to the country it appears as Nissan LD20 Model 1987 and in some spare parts that I also got
16 years 1 week before #8420 by manual-mecanica
Is it diesel or benkinero?, what displacement has and what model of Nissan is originally, these data would help us find what you are looking for.
