Please help me, I have an HDI boxer, it doesn't start
15 years 10 months before #9352 by manual-mecanica
Dear postpers and friends, I have a 2.0 -liter Peugeot Boxer with Common Rail (HDI) system which does not start with the tablet. But if they push it with another car, it is well, only that I have to leave it with the engine running because when stopping the engine does not start; The starter engine is in perfect condition I have checked with a technician, they have told me that it could be the pressure of the pump, can you help me? Cracias
15 years 9 months before #9366 by manual-mecanica
Hello, how about Ecuador, but part of you are for 2 things excess of return in the injectors or the wing pump is spent, it is enough that an injector is off the out of rank that does not start, now if you have scanner you can see in the same as the pressure at the time of starting has to be more than 200 bar.
15 years 9 months before - 15 years 9 months before #9367 by manual-mecanica
99% of that problem are the injectors the precion goes for the return greetings
Last edition: 15 years 9 months before by .
15 years 9 months before #9416 by manual-mecanica
Hi, I'm from Argentina, I have a diesel bomb workshop and I tell you that it is almost certain a problem with the injectors
15 years 9 months before #9429 by manual-mecanica
First of all you have a light check light, apart can be tested without an analyzer if it is an injector that you are open, then the diesel filter how long it has, there are so many things that can influence but you have to give me, more data, greetings Alf.-
