Air conditioning problem 2000 VW Jetta VR6
15 years 8 months before #9977 by manual-mecanica
Air conditioning problem 2000 VW Jetta VR6 published by Manual-Mecanica
Good ..... I hope you can help me .... I am working on a 2000 vw jetta .. it is a vr6 .... What happens is that I do not have positive in the clutch of the air compressor ... Then I am trying to look for the relay of it and I do not know what it is ... I have no manual of the car ... already poor some relay that I found on the side of the driver below ... They work ... when I turn on the air and still do not engage the compressor ... I would like to get an electrical diagram .... so at least I could know ... how to monitor the rabes and which I can JUMPER ... I would also help me know what is exactly the relay of the air conditioner ... and where it is located ..... I am very grateful for your help borrowed ... we are in contact ...
15 years 8 months before #9979 by manual-mecanica
Manual-Mecanica Response on the Re: Air Conditioning Problem 2000 VW Jetta VR6
Assuming that it is non -climatronic manual control under the SERCA battery of the radiator carries a relay module with 2 plugs one of 4 pins O0tro of 14 pins this is responsible for activating first and second of the fans with the second a/Cy with the engine heating and remove positive vel from the compressor.
As you say activates the first of the fans and not the compressor 2 probable things The compressor coil if the positive one that should reach the coil puts a tester and turns on and turns off your tester does not work the coil to get out of doubt looking for any vobine and connect it to the original compressor connector of the compressor. From relays because if you activate the fans it means that all the signals are working, I tell you because I dedicate myself to this greetings from Cancun: Woohoo:
15 years 8 months before #10021 by manual-mecanica
I was checking the system today ... and if you have the relay module under the battery near the radiator
... I am already looking for a clutch of the compressor ... because this definitely does not work ... I put direct current and not active at all the compressor ... You say .... and I don't press the tester ... and how I commented on you ... I had Freon full and I was turned on by the fans .... I must then spup that this relay module is wrong? ....... Is there no thing that can be?
15 years 8 months before #10040 by manual-mecanica
I am sure that it is only the coil is a common fayo in this model, it is to change it or send it to embobe again, if what you want is to be sure if in good condition the module of relays there is no other it has to have a coil in good condition is that simple I will try to upload the diagram of your car if I fail to upload leave me an email greetings : Woohoo:
15 years 8 months before #10041 by manual-mecanica
Hello .... Definitivment the coil does not work and I am trying to look for another coil to change
sela ... even disarma it .. now it is a matter of finding another ... because as you know those parts they are expensive ... I hope Fans that turn when the A/C ... cres can be active? ... hahahaha. Thank you for your Atension ... we are in contact and Oajala can see that diagram and know how that relay module works ... well this is my email And good night.
