, it is on a Ford Focus 1.6 gasoline 100cv, it is the 8 Zetec valves of 2003,
it accelerates in cold a barbarity almost 2000 rpm in 7/8 minutes is stabilized at 900/800 rpm when cooling the engine a couple of hours to start it and again, they have changed it again, they have changed it again, Butterfly position sensor, cylinder head sensor (this model is mounted on the cylinder head between the low), new spark plugs /Motable Motorcraft cables, Bosch coil, a professional Scanner, does not give any error this is doing as 6 months ago, previously perfect it accelerated a little cold cold, but at 1000 rpm little more, at minute approx. It stabilized perfect, apart and noticed that consumes much more, logical every day when starting 2000 rpm, the mechanic as he says can continue to be tested with Lamda / thermostat probe / I have spent 400 € and nothing!
AAA A VIED BODY BODY CLEANING AND POSSIBLE LEAKS, REAPPREDED ADMISSION collector and do not explain it, thanks for reading my odyssey, greetings to all
