Hello, I have a 2009 Ford Econoline, Diesel Engine 6.0 Lts., That arrived at the workshop with the toothpray (zipper) of the slaughtered engine, the tooth was changed, the converter (turbine) was checked and no additional damage was found, it was detected that only the start produced a more severe noise than normal, it was explained to the person in charge of this vehicle (it is an ambulance) and He worked only a few days and was damaged again with the same rupture pattern, I would like to know if any partner has had a similar problem before, to share it with me, thank you.
