Wiring of the Daihatsu Wide 55?
10 years 11 months before #46692 by manual-mecanica
Wiring of the Daihatsu Wide 55? Posted by manual-mecanica
Hello, I have a Daihatsu Wide 55 I had it for 12 years ago I changed everything and I made it start I had to change the gasoline float with followed one tried it before putting the tank and everything worked well I put the naphtha tank and gave him surprise! The car does not turn only on the high and low and very dim light those of rotation do not turn on, I took out the donkey and turned on the lights blink a little and died, I took out the gas tank and also began to flash and also died, I said any mass problem is fucking it is fucking to look and the cables are all researches to cake, now start to make a cable to make a cable to make a cable to make a cable Do you have the diagram to turn on the WIDE engine ??? Xq I already pull the donkey to the alternator and the ignition key but from there for the coil and the voltage regulator we do not know how they connect anyone know ???
