Problems at Subaru Legacy Sedan 91
15 years 2 weeks before #14053 by manual-mecanica
Problems at Subaru Legacy Sedan 91 published by Manual-Mecanica
I need them to help me, I suffered from the theft of my jewel and when I recover it for a problem that I have not been able to detect my car, it is generally stopped between 20 and 60 km per hour, when it reaches the seventies it is released and normally walks, but under sixty and appears again the braking on the wheels destabilizing a little and giving the typical sounds of wheels skating, some mechanic told me that they would Injectors or refinement but clean everything and remains the same I suspect as if it were traction.
14 years 11 months before #14744 by manual-mecanica
Manual-Mecanica Response on the Re: Problems in Subaru Legacy Sedan 91
Some Subaru have a device called mountain brake, it is connected from the clutch to the brake system with a piola if it is badly regulated, it may produce a fault similar to the one that your accounts check that, or simply disconnect it. To do this you have to release the piola that goes from the clutch to the brake system is super simple and try if it is removed if that is then you can connect it ...
14 years 11 months before #14749 by manual-mecanica
It is true what Kadett says but there a calibrated spring that deals with keeping Breack assembles active, usually when he fails the vehicle is braking and then removes it is not the setback but prove what he tells you if you do not get anything, you will study your case while.
