Toyota water pressure
14 years 11 months before #14672 by manual-mecanica
Toyota Water pressure published by Manual-Mecanica
Hello everyone, I have a Turbo Diesel 3.0 Toyota that passes the 3000 laps throws all the water through the recovery bidon, if I keep it to a city regime, it has no problem or temperature or water consumption, I change the lid of the radiator and the thermostat, clean the radiated and remain the same. Some grateful fact. Julio hug
14 years 11 months before #14681 by manual-mecanica
Manual-Mecanica Response on the Re: Toyota Pression of Water
The most caused thing is that it is the inpaquetura of the cylinder head, and the altoger filters the partner towards the refrigeration system, I check this, but before a query, on the bottom and high the fan enters well?
14 years 11 months before #14684 by manual-mecanica
Thanks is the only thing that I need to try, the perfect coupled fan .... Julio hug
14 years 11 months before #14754 by manual-mecanica
I agree with Kikemec, it is very possible that you have the Board of Bad Board and be Fushing compression gases to the cooling circuit.
Another thing to look at too and look at it before anything is that the thermostat opens at all, since sometimes partially opens and for low power ranges (urban cycle) the water flow that lets pass is enough, but when you leave the road it causes the engine to heat up and boil the water.
All the best.
