I need help with Ford Explorer XLSW 2000
14 years 11 months before #14842 by manual-mecanica
I need help with Ford Explorer XLSW 2000 published by Manual-Mecanica
Hello everyone if it is in your hands to help me, I will thank you for a lot, the thing is next. In the mornings or when my Ford is cold and I start it (start) it accelerates intermittently for a few minutes and then I match, I also need to know what kind of oil I have to put the engine because it already passes from the 140000 km prompt response or guide, a hug.
LUISYOVA72
14 years 11 months before #14894 by manual-mecanica
Manual-Mecanica Answer on the Re: I need help with Ford Explorer XLSW 2000
Hello ....
I hope to help ..
what paza your explorer is normal cars accelerate a bit when they are cold until they reach their normal temperature ..
(at the temperature that needs to work its engine so that the gasoline keme is well aga))
the oil that must be used is multigrade!
I recommend the Mobil 7500 or Castrol ..
already if you have money and you like to put it good, do not burn the castrol synthetic oil ... it is very good and endures more
I hope it serves something my comment: D
luck: SIDE:
14 years 11 months before #14895 by manual-mecanica
Ok I thank you very much about your comment regarding the acceleration, look good on my question is intermittent and that does not seem normal, it comes from well accelerated to almost going out and the oil I mean if I can use 20W50 or I put one more fine? Remember that it has more than 148,000 km excuse me that I am so disturbed but I thank you very much your comment since you were the only one that I answer I be using an not suitable oil for the engine. Thank you very much again.
A hug.
14 years 11 months before #14897 by manual-mecanica
Hello ... you are not right xD, it will not be read
because of the oil if 20W50 is fine ...
of the acceleration .... do you mean that it accelerates and decelerate? '
Do you have the acceleration body?
And the Yack valve?
14 years 11 months before #14900 by manual-mecanica
If that is accelerated and decelerated abruptly until a few minutes pass and match a lot but not quite,
thank you very much for the help
greetings
