Diesel filter
14 years 11 months before #14886 by manual-mecanica
Gasail filter published by Manual-Mecanica
Hello everyone. I need a small help, I have an Alfa Romeo 147 JTDM and I want to change the diesel filter remove it, there is no problem but when riding it, do I have to fill with diesel? Or it is filled alone. Thank you
14 years 11 months before #14899 by manual-mecanica
Manual-Mecanica Response on the Re: Gasoil Filter
Hello ... hahaha
looks at the filters, the gas pump fills them alone, just put it azi empty ..
Open i closes the unoz switch 3 times ...
the pump fills the gasoline filter ..
: SIDE:
luck xD !!
14 years 11 months before #14904 by manual-mecanica
If you fill it, you will avoid a headache and a lot of precaution with the diesel that made it not to leake it .... CAPICHI ...... : Silly:
14 years 11 months before #14912 by manual-mecanica
hello.
Install it empty it is not necessary for you to fill it.
14 years 11 months before #14915 by manual-mecanica
Thank you all. ;)
