Help ... Urgent
14 years 10 months before #14939 by manual-mecanica
Help ... Urgenteee published by Manual-Mecanica
I need help have an automatic accent98 Hyundai, 4 `door, the problem is that several days ago the cart fails the exit or lifts from this, because I change spark plugs, air filter, gasoline filtyro, take away the catalyst since it was obstructed, and the problem persists, since when I turn it on and I will leave I have the same problem. Perfiego also changed automatic cash oil and nothing ,,, and when I go running the box does the changes simply the problem is the exit, the scans already happens and does not throw a code since there is not a checkngine. What could it be? SOS Help please thanks
14 years 10 months before #14970 by manual-mecanica
Manual-Mecanica Response on the Re: Help ... Urgent
Does it tend to turn off at the exit? If you get it on revolutionary, do you do well?
14 years 10 months before #15149 by manual-mecanica
It does not tend to pay, the problem solves it was the pulley where the alternator's girdle and the Cram sensor rest.
