L300 mitsubishi truck
14 years 10 months before #15600 by manual-mecanica
L300 Mitsubishi truck published by Manual-Mecanica
Hello to whom I can help me: I have trouble lighting this vehicle. The issue is that I break the time strap and since I do not know the system I do not know if I bend valves the engine I would like to guide me in this I would appreciate it
14 years 10 months before #15608 by manual-mecanica
Manual-Mecanica Answer on the Re: L300 Mitsubishi truck
If you bring 24 valve engine .... If valves are folded ... if you have doubts, just Czech compression and you will realize ...
14 years 10 months before #15625 by manual-mecanica
That truck in all its double valves immediately, Hojo with the setting if it is the one that brings two straps with counterweight.
14 years 9 months before #15741 by manual-mecanica
Thank you for responding, but no, it is a VA L300 of the year 92 engine 2.4 and it is a lift with multipunto ignition and injection distributor
14 years 9 months before #15752 by manual-mecanica
You checked fuel pressure, eye with the air passage may be the problem, if you keep it accelerated in the same way, you measure comprehension for the theme of the valves you mentioned? When you start it does it with Fuersa, give us more data to help you.
